Hi, I just updated to the latest versions
Home Assistant Core 2022.6.5
Home Assistant Supervisor 2022.05.3
Now I cant restart the system as it says configuration is not valid: integration error: updater.
What action should I take?
Logger: homeassistant.components.websocket_api.http.connection
Source: components/hassio/init.py:684
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 10.21.00 (2 occurrences)
Last logged: 10.22.43
[1858857808] The system cannot restart because the configuration is not valid: Integration error: updater - Integration ‘updater’ not found.
Traceback (most recent call last): File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 193, in handle_call_service await hass.services.async_call( File “/usr/src/homeassistant/homeassistant/core.py”, line 1704, in async_call task.result() File “/usr/src/homeassistant/homeassistant/core.py”, line 1741, in _execute_service await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)( File “/usr/src/homeassistant/homeassistant/components/hassio/init.py”, line 684, in async_handle_core_service raise HomeAssistantError( homeassistant.exceptions.HomeAssistantError: The system cannot restart because the configuration is not valid: Integration error: updater - Integration ‘updater’ not found.
