Can someone explain to me how can i fix this error caused by this card that i have? It is causing an overload of the websocket
type: custom:vertical-stack-in-card
cards:
- type: custom:clock-weather-card
entity: weather.openweathermap
sun_entity: sun.sun
temperature_sensor: sensor.outdoor_temp
weather_icon_type: fill
animated_icon: true
language: en
time_format: 24
hide_date: true
hide_today_section: false
hide_forecast_section: true
hide_clock: false
hourly_forecast: false
use_browser_time: false
- type: weather-forecast
show_current: false
show_forecast: true
entity: weather.accuweather
forecast_type: daily
- type: custom:hourly-weather
num_segments: '4'
label_spacing: '2'
icons: true
show_precipitation_amounts: false
show_precipitation_probability: true
hide_temperatures: true
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/http.py:202
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 19:58:08 (66 occurrences)
Last logged: 20:37:27
[139731197260608] John from 192.168.1.180 (Mozilla/5.0 (Linux; Android 13; SM-X200 Build/TP1A.220624.014; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/120.0.6099.43 Safari/537.36): Client unable to keep up with pending messages. Reached 4096 pending messages. The system's load is too high or an integration is misbehaving; Last message was: {"id":569,"type":"event","event":{"result":"Σπίτι","listeners":{"all":false,"entities":["binary_sensor.bed_sensor_giannis","device_tracker.ioannis_kapoglou"],"domains":[],"time":false}}}
[139731763266112] John from 192.168.1.180 (Mozilla/5.0 (Linux; Android 13; SM-X200 Build/TP1A.220624.014; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/120.0.6099.43 Safari/537.36): Client unable to keep up with pending messages. Reached 4096 pending messages. The system's load is too high or an integration is misbehaving; Last message was: {"id":526,"type":"event","event":{"type":"hourly","forecast":[{"condition":"cloudy","precipitation_probability":0,"datetime":"2023-12-19T21:00:00+00:00","wind_bearing":247,"cloud_coverage":97,"temperature":3.4,"pressure":1023.0,"wind_speed":9.22,"precipitation":0.0,"humidity":89},{"condition":"cloudy","precipitation_probability":17,"datetime":"2023-12-20T00:00:00+00:00","wind_bearing":246,"cloud_coverage":97,"temperature":4.4,"pressure":1023.0,"wind_speed":10.76,"precipitation":0.0,"humidity":85},{"condition":"rainy","precipitation_probability":87,"datetime":"2023-12-20T03:00:00+00:00","wind_bearing":247,"cloud_coverage":100,"temperature":5.5,"pressure":1022.0,"wind_speed":13.39,"precipitation":3.49,"humidity":96},{"condition":"rainy","precipitation_probability":100,"datetime":"2023-12-20T06:00:00+00:00","wind_bearing":247,"cloud_coverage":100,"temperature":5.0,"pressure":1023.0,"wind_speed":8.71,"precipitation":3.8,"humidity":98},{"condition":"rainy","precipitation_probability":61,"datetime":"2023-12-20T09:00:00+00:00","wind_bearing":273,"cloud_coverage":100,"temperature":5.3,"pressure":1024.0,"wind_speed":4.21,"precipitation":0.36,"humidity":97},{"condition":"rainy","precipitation_probability":49,"datetime":"2023-12-20T12:00:00+00:00","wind_bearing":292,"cloud_coverage":97,"temperature":6.5,"pressure":1023.0,"wind_speed":8.86,"precipitation":0.13,"humidity":81},{"condition":"cloudy","precipitation_probability":11,"datetime":"2023-12-20T15:00:00+00:00","wind_bearing":293,"cloud_coverage":98,"temperature":4.3,"pressure":1023.0,"wind_speed":7.81,"precipitation":0.0,"humidity":87},{"condition":"cloudy","precipitation_probability":4,"datetime":"2023-12-20T18:00:00+00:00","wind_bearing":255,"cloud_coverage":88,"temperature":3.0,"pressure":1024.0,"wind_speed":7.96,"precipitation":0.0,"humidity":88},{"condition":"cloudy","precipitation_probability":4,"datetime":"2023-12-20T21:00:00+00:00","wind_bearing":219,"cloud_coverage":86,"temperature":3.3,"pressure":1023.0,"wind_speed":8.86,"precipitation":0.0,"humidity":90},{"condition":"cloudy","precipitation_probability":21,"datetime":"2023-12-21T00:00:00+00:00","wind_bearing":228,"cloud_coverage":92,"temperature":3.4,"pressure":1021.0,"wind_speed":12.64,"precipitation":0.0,"humidity":92},{"condition":"rainy","precipitation_probability":51,"datetime":"2023-12-21T03:00:00+00:00","wind_bearing":220,"cloud_coverage":100,"temperature":4.4,"pressure":1020.0,"wind_speed":15.08,"precipitation":0.44,"humidity":95},{"condition":"rainy","precipitation_probability":63,"datetime":"2023-12-21T06:00:00+00:00","wind_bearing":219,"cloud_coverage":100,"temperature":4.7,"pressure":1019.0,"wind_speed":15.19,"precipitation":0.66,"humidity":95},{"condition":"rainy","precipitation_probability":75,"datetime":"2023-12-21T09:00:00+00:00","wind_bearing":222,"cloud_coverage":100,"temperature":5.4,"pressure":1018.0,"wind_speed":17.82,"precipitation":1.51,"humidity":95},{"condition":"rainy","precipitation_probability":77,"datetime":"2023-12-21T12:00:00+00:00","wind_bearing":232,"cloud_coverage":100,"temperature":6.4,"pressure":1015.0,"wind_speed":24.62,"precipitation":0.74,"humidity":94},{"condition":"rainy","precipitation_probability":100,"datetime":"2023-12-21T15:00:00+00:00","wind_bearing":230,"cloud_coverage":100,"temperature":6.7,"pressure":1013.0,"wind_speed":25.02,"precipitation":1.59,"humidity":94},{"condition":"rainy","precipitation_probability":100,"datetime":"2023-12-21T18:00:00+00:00","wind_bearing":235,"cloud_coverage":100,"temperature":7.6,"pressure":1013.0,"wind_speed":25.02,"precipitation":3.91,"humidity":94},{"condition":"rainy","precipitation_probability":100,"datetime":"2023-12-21T21:00:00+00:00","wind_bearing":246,"cloud_coverage":100,"temperature":8.0,"pressure":1013.0,"wind_speed":26.75,"precipitation":3.29,"humidity":94},{"condition":"rainy","preci
