The thermostat is missing "Manufacturer Specific" from its list of supported modes, although the mode is supported
Since I upgraded to 2022.6.0, I started to see the following message for all my Eurotronics Z-Wave thermostats:
The thermostat is missing “Manufacturer Specific” from its list of supported modes, although the mode is supported. Application-specific workarounds may be necessary to switch to “Manufacturer Specific” mode.
Any clue what this means and those workarounds are/could be?
Thanks for your help.
I just discovered the same Message and would also be thankful for advice.
No solutions yet? I’m having the same problem.
I have the same problem, but no solution.
Since upgrading to 2022.9 all thermostats have 2 new entities, but on some the old entity continues operation and the new ones are unavailable, on others it is vice versa.
Edit: 2022.9.5 fixed the issue with the entities after re-interviewing all thermostats. The release notes mention a bugfix which sounds related.
The warning about “Manufacturer Specific” is still there, but seems to have no consequences.
Anyone know how to force the device into “Manufacturer Specific” mode? I am using ZWave JS UI and want to be able to control the valve directly.
Thanks.
You can try this service call within HA:
service: zwave_js.invoke_cc_api
  command_class: "64"
  method_name: set
  parameters:
    - 31
    - type: buffer
      data: [1, 2]
You have to plug in the manufacturer specific data as bytes.
Thanks. Here is the yaml version of the call I ran:
  command_class: "64"
  method_name: set
  parameters:
    - 31
    - type: buffer
        - 2
  entity_id: climate.thermostat_cuisine
and this resulted in the following error:
Logger: homeassistant.helpers.script.websocket_api_script
Source: helpers/script.py:409
First occurred: 18:50:54 (4 occurrences)
Last logged: 18:54:14
websocket_api script: Error executing script. Error for call_service at pos 1: 1 error(s): Endpoint(node_id=32, index=0) - FailedZWaveCommand: Z-Wave error 322: manufacturerData is not a (optional) Buffer (ZW0322)
Try type: Buffer instead.
The service ran Ok, but the the message still appears. I re-interviewed the device, but nothing changes.
