I am running hassio/hassos on local network without extern access for months getting data from sensors via thethingnetwork data integration and The Things Network Component
After upgrade to 088 I get the below CERTIFICATE VERIFY FAILED error.
I never dealed with certificates in my configuration.
I have NO idea how to solve this error…please help!
17:04:50 ERROR (MainThread) [homeassistant.core] Error doing job: SSL error errno:1 reason:
CERTIFICATE_VERIFY_FAILED Traceback (most recent call last): File “uvloop/sslproto.pyx”, line 504, in uvloop.loop.SSLProtocol.data_received File “uvloop/sslproto.pyx”, line 204, in uvloop.loop._SSLPipe.feed_ssldata File “uvloop/sslproto.pyx”, line 171, in uvloop.loop._SSLPipe.feed_ssldata File “/usr/local/lib/python3.7/ssl.py”, line 763, in do_handshake self._sslobj.do_handshake() ssl.SSLCertVerificationError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: Hostname mismatch, certificate is not valid for ‘pv_bmp280.data.thethingsnetwork.org’. (_ssl.c:1056) 2019-02-21 17:04:50 ERROR (MainThread) [homeassistant.components.thethingsnetwork.sensor] Error while accessing: https://pv_bmp280.data.thethingsnetwork.org/api/v2/query/bmp280b`
