The unit of this entity changed from 'kWh' to 'W'
Hello, I had a utility sensor, where the input was W before. I changed the device and replaced the input sensor with another sensor with W, but now i get this warning. I replaced with daily usage sensor (KWh), but still get same error/warning. how can i can fix this? only option i have in the statistics tab is delete old data or change the old data to W.
The Utility Meter only works correctly with energy sensors (Wh or kWh).
Not power sensors (W or kW).
You need to convert your power sensor to energy first using the Riemann Sum Integral helper.
thanks. i didnt know this. i will delete this and add start again.
