Hello. Can you please make an Integration for the KNX Smart home System Luxorliving from Theben? (Ist doesn‘t work with the KNX Integration)
Also having LuxorLiving myself. Can’t wait for Home Assistant support for it!
I couldn’t make it work with Home Assistant KNX integration yet.
Hello. I bought a normal KNX gateway and just plugged it in and I got it working. With the money from tzhe teben gateway I only spend like 50 Euro for the upgrade.
Yes I did the same. Separate KNX IP gateway and works like a charme now with Home Assistant.
Hey, can you please explain a little bit further what you did? So you installed a seperate KNX IP Gateway (which one?) without using ETS or with ETS?
Hi @ all,
I have also LuxorLiving and I bought a separate KNX IP Gateway.
Without ETS it looks like (status LEDs on Gateway) that it is working fine.
In home assistant I was able to connect the KNX Integration to the gateway.
But now I have the problem to tell Home Assistant (KNX Integration) about my LuxorLiving Project.
Thank you in advance. Regards David
Any updates? I need the same setup! Can someone explain more details?
Hello, With which KNX gateway did you upgrade the Luxorliving ip1? Which models work with HA and “old Luxorliving” system?
Which one did you use?
Hi @ all,
I used the cheapest one, which I found.
CONTROLtronic IPI.1.8.2
It works fine out of the box.
But now I see only the KNX communications.
My wish is an easy way to translate it.
Maybe somebody knows how.
Regards David
I used the KNX IP Gateway from MDT:
“MDT SCN-IP000.03 IP Interface 2TE REG” for 150€
https://www.mdt.de/produkte/produktdetail/systemkomponenten/systemgeraete/ip-interface.html
Has to be connected with LAN cable and with your (LuxorLiving) KNX bus and then you can add it to HomeAssistant.
Finding the group addresses for all KNX devices can be quite challenging, I used LuxorPlug software in debug mode, which shows most of the device adresses when hovering over. Also you can use HomeAssistant KNX monitor to view KNX bus messages live. So you just switch on the light and see the KNX monitor in home assistant which address was involved.
I did not use ETS software, just LuxorLiving LuxorPlug software, but our system was already 95% programmed ready by the company we bought the house from. So I only need to make small adjustments using LuxorPlug.
HomeAssistant can send KNX bus messages and control every KNX device of course, like lights, covers, climates, …
Okay so you didn’t use the IP Gateway from Luxor Living? If yes, why?
