Theme Backend selected out of reach
Good to hear it did work. Your issue would seem to be a separate matter, possibly related to the mobile app and/or automation specifically.
It didnt work though.
Its the same issue. Its been this way for months. It ueed to wprk fine. And thr automation works fine on every other browser.
Thing is. Some of us cannot select the backend-select theme option anymore. It used to sometimes work. Now. It just wont show up. Whoch i think started around the timr we got dark and light theme options.
Something changed and it wasnt on my end.
it is required to shrink the browser window several times, e.g. with “ctrl and -” so that the “Backend-selecte” theme appears, which allows you to change the theme using the “frontend.set_theme” service and in the mobile application I don’t know how to do it
But you did open an issue and now it will be on the list of things to be fixed. :+1:
Which you should have done three years ago @Mariusthvdb :slight_smile: I’m surprised it has gone unreported for this long.
haha yes
tbh, I’ve never looked at that again, because my themes are working as expected, and use the backend select.
do have a (probably) related issue though: input_select dropdown wont show completely or scroll down · Issue #9416 · home-assistant/frontend · GitHub
