Theme Backend selected out of reach
HI,
Trying to set the Hassio theme to Backend selected, which is the top theme in the listing, I cant scroll up there, always ends on Default. With great effort, sometimes the Backend shows suddenly, but then one must be really quick …
Is this an UI error?
Secondly, can one set it in the config files, opposed to having to select the theme in the UI?
I know this is old but did you ever get anywhere with this?
I sometimes have the same thing happen.
No, I didn’t. It was there, nobody even noticed my cry for help…
I have my themes set automatically, and never look at that anymore…
How do you set backend select?
click on your profile badge and you should see these options:
38
Yes but sometimes I don’t see backend select!
That was the original problem!
How do you change theme from an automation if you can’t set it to backend select originally?
well, I guess can simply use the automation to set the theme, I think that’s how it was set in my setup while I couldnt see it in the select itself.
this is what I setup, and never look back:
#homeassistant:
#  customize:
# Groups
group:
  theme_selector:
    icon: mdi:palette
    entities:
      - input_select.set_sunrise_theme
      - input_select.set_sunset_theme
      - sensor.sun_based_theme
      - automation.sun_based_theme_change
      - input_select.theme
# Sensors
    sensors:
      sun_based_theme:
        friendly_name: Sun based theme
        value_template: >
          {% if is_state('sun.sun','above_horizon') %}
           {{states('input_select.set_sunrise_theme')}}
          {% else %}
            {{states('input_select.set_sunset_theme')}}
          {% endif %}
        icon_template: >
          {% if is_state('sun.sun', 'above_horizon') %}
            mdi:weather-sunny
          {% else %}
            mdi:weather-night
          {% endif %}
# Inputs
input_select:
  theme:
    icon: mdi:palette
    options:
      - 'clear'
      - 'darkblue'
      - 'darkcyan'
      - 'darkorange'
      - 'darkred'
      - 'default'
      - 'done'
      - 'matrix'
      - 'midnight'
      - 'minimal'
      - 'PmxMononight'
      - 'stormy_hues'
      - 'teal'
      - 'vintage'
#    initial: 'teal'
  set_sunset_theme:
    name: 'Select Sunset theme'
    icon: mdi:weather-night
    options:
      - 'clear'
      - 'darkblue'
      - 'darkcyan'
      - 'darkorange'
      - 'darkred'
      - 'default'
      - 'done'
      - 'matrix'
      - 'midnight'
      - 'minimal'
      - 'PmxMononight'
      - 'stormy_hues'
      - 'teal'
      - 'vintage'
#    initial: 'darkblue'
  set_sunrise_theme:
    name: 'Select Sunrise theme'
    icon: mdi:weather-sunny
    options:
      - 'clear'
      - 'darkblue'
      - 'darkcyan'
      - 'darkorange'
      - 'darkred'
      - 'default'
      - 'done'
      - 'matrix'
      - 'midnight'
      - 'minimal'
      - 'PmxMononight'
      - 'stormy_hues'
      - 'teal'
      - 'vintage'
# Automations
automation:
  - alias: 'Change Current Theme'
    id: 'Change Current Theme'
    initial_state: 'on'
      platform: state
      entity_id: input_select.theme
      service: frontend.set_theme
      data_template:
          {{states('input_select.theme')}}
  - alias: 'Sun based theme change'
    id: 'Sun based theme change'
    initial_state: 'on'
      - platform: homeassistant
        event: start
#      - platform: state
#        entity_id: input_select.set_sunset_theme
#      - platform: state
#        entity_id: input_select.set_sunrise_theme
      - platform: state
        entity_id: sensor.sun_based_theme
#      - platform: sun
#        event: sunrise
#      - platform: sun
#        event: sunset
#      - platform: state
#        entity_id: sun.sun
#        to: above_horizon
#      - platform: state
#        to: below_horizon
    condition: []
#      - delay:
#          seconds: 3
      - service_template: frontend.set_theme
        data_template:
            {{ states('sensor.sun_based_theme') }}
#            {% if trigger.platform == 'sun' %}
#              {{states('input_select.set_sunset_theme') if trigger.event == 'sunset' else
#                states('input_select.set_sunrise_theme') }}
#            {% else %}
#              {{ states('sensor.sun_based_theme') }}
#            {% endif %}
      - condition: template
        value_template: >
          {{ is_state('input_boolean.notify_system', 'on')}}
      - service: notify.system
        data_template:
          title: >
            Ha Main: Sun set Theme
          message: >
            {{ as_timestamp(now()) | timestamp_custom("%X") }}:
            Sun is {{states('sun.sun')}} and Frontend is set to '{{ states('sensor.sun_based_theme') }}'
I like your setup and might borrow some of it’s flexibility! But I’m still not sure this solves my problem.
I currently use this simple automation:
automation:
  - alias: Set Theme
    hide_entity: true
    initial_state: true
      event: start
    - platform: state
      entity_id: sun.sun
      to: above_horizon
    - platform: state
      entity_id: sun.sun
      to: below_horizon
      data_template:
          {% if states('sun.sun') == "above_horizon" %}
            day
          {% else %}
            night
          {% endif %}
But it seems to me that service: frontend.set_theme only works if the theme is set to backend-selected which I can’t get to on my mobile!
Do you mean that’s what would be expected, or did you in fact experience this? I seem to recall that by using these automation the selection is set to backend…But as said, I havent checked in a long time, so not really sure.
On my mobile I cannot set my theme to backend-selected.
This means that calling the service will not change the theme when the automation runs.
Which actually raises a question. In the HA menu you set the theme on a per-user basis but this does not seem to get applied to all devices logged on as the same user.
Unless of course this is a cacheing issue, but then how do you force a full reload on a mobile device using Chrome when the webpage (in this case HA) has been saved as an ‘app’?
Im not sure if that’s true, at least, Ive never experienced that. For what I see, the theme is applied to the instance, not to the device it is displayed on. Even more, I have 3 users configured, and on all of these, the theme is automation theme does its job… Maybe it shouldn’t be on the user page after all, it was on the general strings page before.
Unless this is all based on the fact I havent ever set a user based theme, and the system simply hasn’t recorded any personal settings related to theme, and is still listening to the automation, as it has always done…
maybe ask one of the dev’s or architects on this subject, and while you have their attention, throw in the issue of the backend select not being visible at all times.
how do you even do that? I tried it just now, but only see the option of creating a bookmark, not save on desktop or something like that…
Top right three dot menu in Chrome, ‘Add to Home Screen’.
(This is on an Android phone)
Gives a shortcut on the Home screen that acts a bit like an app. i.e. it is really Chrome displaying the webpage but with no menus or address bars or any other screen ‘furniture’.
I’ve only used Discourse a few times to ask a question and never had a response. Which is fine if no one wants to reply or knows the answer but the problem with it is that the question then gets lost.
I prefer this forum…
Unless you can tell me I’m using Discourse wrongly. (Which I wouldn’t be surprised about as a lot of people love it!)
well, its not there on iOs… now the procedure, but nit with Chrome unfortunately…
only been on Discourse once, so wouldn’t be a fair judge. With you on this forum, and the history of posts we can revisit. Like this one :wink:
Even so, this doesn’t seem to bother people, though a nasty little bugger it is.
I’ve just discovered that if you go to the three dots menu then tick the desktop site box you can "reach"up to choose backend-selected. Hope this helps
After months of not understanding why I couldn’t find the “backend-selected” option on a particular device I decided to check the forums and since I’m not alone, here’s my experience…
The device had a manually selected theme, and the option for “backend-selected” was missing. Logging in on another device with the same user, it defaulted to “backend-selected” there, but on the problem device it remained the same (Service: frontend.set_theme had no effect - the theme could only be manually set)
Conclusion: the Theme setting from the User menu is cached with the logon session
Solution: Log out on device and then log back in.
bumping this as its still a problem.
using latest HA core. and latest ha official app.
Cant select backend-selected on mobile.
doesnt work unfortunately.
Logging out from User Profile should correct this. In the mobile app, you could also try clearing the app’s cache from Android’s App management.
Just tried that, it did change it back to backend selected. however, it didnt actually change to the right theme, I have the automatons where I can change the theme from a view and it will change on all my devices, which works, except for the mobile. Even with it on backend selected it was actually the default theme instead of the custom ones my other devices have. also, it wasn’t in the list anymore, so when i changed it again, its gone again.,
