Theme change at Time
I know it muss be a small fault. but i don’t see him
the Logs says:
ERROR (MainThread) [homeassistant.config] Invalid config for [automation]: [after] is an invalid option for [automation]. Check: automation->trigger->0->after. (See /config/configuration.yaml, line 200). Please check the docs at https://home-assistant.io/components/automation/
on Line 200 in configuration.yaml is:
automation: !include automation.yaml
the code where i use:
  - alias: 'Set dark theme for the night'
    initial_state: True
      - platform: time
        after: '22:00:00'
      - service: frontend.set_theme
see somebody the fault?
Thanks for your Help!
Use at: instead of after: for time triggers.
With this works:
    initial_state: True
      - platform: time
        at: '18:45'
