Theme cut off at top of iOS app
Bit neurotic on my part, but my dashboard theme gets cut off at the top of the HA iOS app. See below:
The theme turns dark gray at the very top. I’m not sure if this is a limitation of the particular theme I’m using, or all themes for HA. I tried a few different themes and they all get cut off.
The current theme I’m using is ios-dark-mode-blue-red
Any way to fix this?
Not using these themes. If you say that an upper part of an image is clipped - then this is probably caused by a wrong css for background (a whole image must cover all available area w/o overflow) in a theme.
