I’ve just tried my first, one-line theme. In configuration.yaml I have
frontend:
themes: !include_dir_merge_named themes
and in the folder themes a file erkennbar.yaml with
erkennbar:
state.person.home.color: "#FCBE2D"
(I first thought the theme was the file name and got errors until I added it inside the file.) In the dashboard I can and have chosen the theme and there are no errors, only the colour in the histories (both card inside the dahboard and page) does not change.
The reason: one in ten men is colour deficient to a larger or lesser degree and I have a strong variant. Switches and binary sensors are fine with their bright yellow against blue-grey. But the home/away of people is more or less indistinguishable.
N.B: Once I’ve got this working I’m sure to come back for more. I’d like to tinker with font size (larger) and line spread (smaller) for better legibility and less scrolling on small screens.
Danke
Great. Thank you very much. That did the trick instantly. Now I can see everything at a glance. It doesn’t seem to influence the history page though, just the card. Is that a bug or a feature? Any way to make the page easier to see too?
Danke
As explained above, the standard colours for home and away are just about identical for me. Defeats the purpose of the history graph. I can theme a dashboard but not, it seems, the history page.
Are those the standard colours? They look slightly different from mine, but not much, might be the copying. If you changed them, then how? (Pink, green, grey, it’s all much the same. Blue vs. yellow is the contrast I can see well.) In the dashboard I can load a theme and it works, but for the history page I see no way.
Danke
