Hello ther i,am working on mine lovelace with plants, now i have one room filled with plants is it possible to give this room a specific background with a wallpaper or picture that only show up in this room
with regards Xal
with regards Xal
Hello xallias,
This should be achievable if your plant room is a separate lovelace dashboard. I am not aware of a method to do this to a single view within a dashboard, though perhaps others are.
Themes allow you to override any CSS property, including background-image
If you look at the theme format documentation you will see this:
frontend:
themes:
happy:
primary-color: pink
text-primary-color: purple
mdc-theme-primary: plum
sad:
primary-color: steelblue
Two themes are defined, happy
and sad
. In this example, the sad theme sets the primary-color
CSS property to steelblue.
If I were you, I’d try using the same mechanism to set the background-image
CSS property, and then apply this theme to just the dashboard that contains your plants view.
Thx iam gonna try this
With regards Xal
