I am using the “midnight” theme which can be found here.
Everything was fine, however after the last update my dashboard is showing white background instead of the dark gray color (#434954).
How can I get it to display gray instead of white?
midnight:
accent-color: "#E45E65"
card-background-color: "var(--primary-background-color)"
dark-primary-color: "var(--accent-color)"
disabled-text-color: "#7F848E"
divider-color: "rgba(0, 0, 0, .12)"
google-blue-500: "#4285f4"
google-green-500: "#39E949"
google-red-500: "#E45E65"
google-yellow-500: "#f4b400"
ha-card-background: "#434954"
label-badge-background-color: "#2E333A"
label-badge-blue: "#039be5"
label-badge-border-color: "green"
label-badge-green: "#0DA035"
label-badge-grey: "var(--paper-grey-500)"
label-badge-red: "var(--accent-color)"
label-badge-text-color: "var(--primary-text-color)"
label-badge-yellow: "#f4b400"
light-primary-color: "var(--accent-color)"
markdown-code-background-color: "var(--paper-listbox-background-color)"
paper-card-header-color: "var(--accent-color)"
paper-dialog-background-color: "#434954"
paper-grey-200: "#414A59"
paper-grey-50: "var(--primary-text-color)"
paper-grey-500: "#9e9e9e"
paper-item-icon_-_color: "green"
paper-item-icon-active-color: "#F9C536"
paper-item-icon-color: "var(--primary-text-color)"
paper-item-selected_-_background-color: "#434954"
paper-listbox-background-color: "#2E333A"
paper-listbox-color: "var(--primary-color)"
paper-slider-active-color: "var(--accent-color)"
paper-slider-container-color: "linear-gradient(var(--primary-background-color), var(--secondary-background-color)) no-repeat"
paper-slider-disabled-active-color: "var(--disabled-text-color)"
paper-slider-disabled-secondary-color: "var(--disabled-text-color)"
paper-slider-knob-color: "var(--accent-color)"
paper-slider-knob-start-color: "var(--accent-color)"
paper-slider-pin-color: "var(--accent-color)"
paper-slider-secondary-color: "var(--secondary-background-color)"
paper-tabs-selection-bar-color: "green"
paper-toggle-button-checked-bar-color: "var(--accent-color)"
paper-toggle-button-checked-button-color: "var(--accent-color)"
paper-toggle-button-checked-ink-color: "var(--accent-color)"
paper-toggle-button-unchecked-bar-color: "var(--disabled-text-color)"
paper-toggle-button-unchecked-button-color: "var(--disabled-text-color)"
paper-toggle-button-unchecked-ink-color: "var(--disabled-text-color)"
primary-background-color: "#383C45"
primary-color: "#5294E2"
primary-text-color: "#FFFFFF"
secondary-background-color: "#383C45"
secondary-text-color: "#5294E2"
sidebar-background-color: "var(--paper-listbox-background-color)"
sidebar-icon-color: "rgba(255, 255, 255, 0.70)"
sidebar-selected-icon-color: "var(--primary-color)"
sidebar-selected-text-color: "var(--primary-text-color)"
sidebar-text-color: "var(--primary-text-color)"
slider-bar-color: "var(--disabled-text-color)"
slider-color: "var(--primary-color)"
slider-secondary-color: "var(--light-primary-color)"
st-mode-active-background: "var(--dark-primary-color)"
st-mode-background: "var(--primary-background-color)"
state-icon-active-color: "#FDD835"
state-icon-color: "#44739e"
state-icon-unavailable-color: "var(--disabled-text-color)"
switch-checked-color: "var(--paper-toggle-button-checked-button-color)"
switch-unchecked-button-color: "var(--disabled-text-color)"
switch-unchecked-color: "var(--disabled-text-color)"
switch-unchecked-track-color: "var(--disabled-text-color)"
table-row-alternative-background-color: "#3E424B"
table-row-background-color: "#353840"
text-primary-color: "var(--primary-text-color)"
toggle-button-color: "var(--primary-color)"
