Thermia heatpump - Understanding the sensors and behaviour
Hi all,
I’m using the thermiagenesis custom integration created by @CJNE . Thank you for this great integration, saved me a lot of time.
The integration allows me to take control of my heatpump and define setpoints & operating modes in a more dynamic way.
At this moment, I’m trying to understand the heatpump’s behaviour, as well as trying to understand the meaning of the many sensors that come with the integration.
This leads to some questions:
  • As you can see in the screenshot above, the room temperature is always at 0 °C, and the room temp setpoint is 21 °C. I don’t understand why this is not showing the currect room temp.
  • During the night, the heatpump doesn’t operate to heat the house, and typically at 5h in the morning the heatpump starts operating again.
    I have been looking at the “system supply temperature”, which seems to be above its setpoint during the night. That could explain why the heatpump is not running then, but it’s strange to see that the “system supply temp” remains above setpoint without the heatpump generating heat.
    Underlying question is: I’d like to understand this process, and therefore I’d like to know which temperature sensor is measured where in the installation.
Anyone who also has the Thermia heatpump and using the integration, who could help out?
Thanks in advance.
I’m glad that you have found some use for the integration!
For your first question, the room temperature sensor is not always installed, are you sure you have one?
I don’t have it and I also have 0 for room temperature.
Your other question is a bit trickier, do you mean that system supply line temperature increases without the heat pump running? It would be interesting to see a graph for heat pump selected gear for the same time period.
Newbie here - where can I find this integration? Thermia doesn’t seem to be listed under Integrations.
My technician told me this is rarely installed. The heat pump simply checks the difference in temperature between the water going in and coming back (return valve). If that’s bigger than value X, it continues to heat.
I just started playing around with the ThermiaGenesis integration. Thanks for this fantastic tool!
I have a question for CJNE:
In the integration, there are two sensors called ‘sensor.high_pressure_side’ and ‘sensor.low_pressure_side’. They show temperature in degrees celsius.
Looking at the Modbus manual for Thermia Genesis, I find on Pg13 ‘Input registers, function 4’ following: High pressure side, pressure (bar(g)), addr 127 and Low pressure side, pressure (bar(g)), addr 128.
My question: Should the ‘sensor.high_pressure_side’ and ‘sensor.low_pressure_side’ not have bar(g) as units?
Thanks!
I am working on a picture elements card containing some of the sensors; still figuring out a lot and learning along the way.
Best regards,
Rogy
Here is what I am working on:
Will be happy to share if I can get it to work :slight_smile:
Hi Rogy,
Did you get the interface working? :slight_smile:
Might also want to use it for my Thermia Kalibra 7
Kind regards,
Maarten.
@michaelpiron sorry for responding to this old thread but not too much info on Thermia and HA. I just started with HA and this integration. Relatively newby as i used Domoticz for the past 10 years or so. I have two questions:
  • Would you be willing to share your Yaml for above dashboards? I really like the added graphs and colored status.
  • I managed to ‘automate’ the tapwater heating moments to the times that typically my solar panels have the best yield. I would also like to include the boost function in this (is it same as legionella cycle?) in case of really good solar performance.
    Would you have an idea what registers are used for that? in the Android App it is a ‘button’ I would like to add such button in HA to be used for automations.
    Thanks!
    Michel
@Rogy Just started with HA and Thermia heatpump. Did you get the above working? I would be really interested in a ‘share’ :slight_smile:
Cheers,
Michel
Has anyone figured out how to delay the reheating process? I see a spike in my energy usage after my family’s morning shower. I would like to delay this reheating until there is solar energy
Hi everybody,
It looks like the heating season has started again.
I finally found some time to finish the dashboard to monitor my Thermia heatpump.
For those interested, have a look here: GitHub - igordockx/HA-Thermia-Genesis-Monitoring: Home Assistant dashboard for monitoring Thermia Genesis heatpumps
I am not a coder and Github is new for me; don’t hesitate to let me know if things are unclear or can be improved :slight_smile:
Best regards
Cool!! Will definitely try this one this season. Thanks!
What kind of automations are you using in combination with the Calibra?
