I have a new, first-time installation, everything seems to work but I have the same situation as above and with this red square blinking. I use the downloaded ThermIQ_Card.yaml. I have the first gen 1 ThermIQ-room with fw v.2.23. No alarms are active.
Is there any reason this should be visible and how can I fix it?
Please update your fw first and see if that makes any difference. Secondly, I’m not sure you have the hardware required for EVU to function, a hw upgrade might be necessary…
Did some maintenance and tried to update the device thru the meny button on the device (counts down ) but keep getting invalid cert. Did something change?
