One of my bedrooms gets significantly warmer than others. My goal is to make an automation that will trigger the thermostat to run the furnace fan to circulate air when that room gets a few degrees warmer than the rest of the house. I’ve places an Aqari temp sensor in the room and it’s reading correctly, I just need help with the YAML. This is what I’ve got so far but it’s not working correctly. It isn’t triggering on its own, and if I manually run it it runs for 12 hours. I’d like it to run for maybe 5-10 minutes then recheck if there is still a temperature delta.
alias: "RUN fan "
description: ""
- platform: numeric_state
entity_id: sensor.lumi_lumi_weather_temperature
for:
hours: 0
minutes: 5
seconds: 0
above: sensor.nest_thermostat_temperature
value_template: "2"
condition: []
- if:
- condition: not
conditions:
- condition: device
device_id: 91ae04294de2ef5b522104c1b2ede415
domain: climate
entity_id: climate.nest_thermostat
type: is_preset_mode
preset_mode: eco
then:
- service: climate.set_fan_mode
fan_mode: "on"
else:
- stop: "In ECO Mode "
mode: restart
The value_template
line in your trigger isn’t correct. From what you posted I would guess you actually be better off with a template trigger. While you can do something similar using the Numeric state trigger with a value template, it has a major drawback when comparing two entities with highly dynamic states.
value_template: |
{{ states('sensor.lumi_lumi_weather_temperature')|float(0) -
states('sensor.nest_thermostat_temperature')|float(0) > 2}}"
for: "00:05:00"
As shown, there’s no action to turn off the fan.
Thanks for that. I’m not sure what to add to turn off the fan or have the automation recycle.
What you add really depends on how you want the automation to behave. In your first post you wrote:
Generally, it’s more efficient (and less complicated to construct) to not employ polling. Instead you would set up a second trigger based on your temperature delta criteria. The following is an example of that.
alias: "RUN fan "
description: ""
value_template: |
for: "00:05:00"
value_template: |
{{ states('sensor.lumi_lumi_weather_temperature')|float(0) <=
states('sensor.nest_thermostat_temperature')|float(0) + 0.5 }}"
for: "00:05:00"
condition: []
- choose:
- conditions:
- condition: trigger
- condition: not
conditions:
- condition: state
entity_id: climate.nest_thermostat|
attribute: preset_mode
state: eco
sequence:
fan_mode: "on"
- conditions:
sequence:
fan_mode: "off"
mode: restart
You will likely need to figure out what other conditions will be necessary for accurately controlling turning the fan on and off.
Thank you. That’s helpful. I’m still learning a lot of this and started the automation in the Automation Editor. I can read YAML sorta, but writing it not so much.
As I understand the code you provided, it looks like it will turn on if the temperature is >2 for 5 minutes and turn off if the sensor is <0.5 degrees delta for 5 minutes. Is that correct? I also see you included the extra but of code for disabling if it’s set to ECO.
I appreciate the help. I’m still learning, as I said.
