I do have two automation for my thermostat which the first one turns off the thermostat when no one is at home and the second one turn it back on when someone is back at home. my problem is I want to get the latest hvac_mode
saved into a variable when turning off the thermostat and call it back when I need to turn back the thermostat. I created below automation and a sensor to keep the last operation mode but it doesn’t work. could anyone help me with this please?
sensors.yaml
thermostat_mode:
friendly_name: "Thermostat Operation Mode"
value_template: >-
{% if is_state('climate.thermostat', 'heat') %}
heat
{% elif is_state('climate.thermostat', 'cool') %}
cool
{% endif %}
automation.yaml
- id: '1561438325619'
alias: Thermostat Away Mode
- entity_id: group.all_devices
platform: state
condition: []
- data:
entity_id: climate.thermostat
service: climate.turn_off
- id: '1561589408139'
alias: Thermostat Home Mode
platform: state
to: home
condition: []
- data_template:
hvac_mode: '{{states.sensor.thermostat_mode.state}}'
service: climate.set_hvac_mode
in my sensor I’m trying to just keep cool
or heat
and not other modes like off
but when I turn off the thermostat my sensor value will be empty and when thermostat is on it’s either cool
or heat
I’m not sure why the sensor value becomes empty when I do have 2 ifs to only change the value between cool
and heat
. in fact my first automation is ruining my sensor value but second automation works fine. What should I do on my sensor template to prevent that?
