My issue is my thermostats which are connected through Vera, do not display the correct heat set temperature when the thermostat is in heating mode. Initially they will display the correct temperature but after some time they will display the cool set point until someone adjusts the heating set point at which time they will temporarily display the heat set point but then revert to displaying the cool set point. As you can see from the screen shot ALTUI can properly see the set points and so can my vera. The correct set points are available but for some reason the thermostat card reverts to displaying the cool set point after a seemingly random amount of time.
Any ideas?
