I dont want to use the dropdown so I opted for icons in settings. But I only see dots and no icons. Anyone have an idea of what I’m doing wrong?
I’ve also used simple-thermostat where I can define icons in the code, but have no such luck here.
This is what I get.
// J
The climate integration you are using does not define icons for its fanspeeds. There’s nothing you can do as an end user to affect this, it has to be fixed by the integration.
ah ok, that’s too bad.
Thank you for your answer and help.
