Probably a really quick one, is it possible to get a ‘fan’ (or recirculate) option working in the new thermostat card or is this a feature request that needs to be created?
I had the thermostat card working in 0.81.0 and the fan mode was present, the icon was just invisible (but fully functional). Since 0.81.1 its now gone, so I was wondering if this was intended?
I’m not seeing a fan_control option in the default lovelace thermostat card:
I’ve tried adding a boolean option for fan_control, fan_mode, fan to the thermostat card configuration and none of them are showing fan controls on the card.
Do you know we will see this released in HomeAssistant?
What I added was mode: fan, not fan_speed control. To get access to that you still need to use the more-info button (vertical …) on the top right to change it.
