Guys, I updated first time in a few months and now have issues with thermostat card. It shows unavailable even it though config looks ok and entities are there. This applies BOTH to ecobee and z-wave baseboard thermostats. Any idea what I could try?
Find in Developer tools -> States your climate.main_floor
and check if it has reasonable data inside.
If yes - it’s UI bug, if not - something in backend…
The sensors from the thermostats are giving correct data, however the actual thermostat is showing is unavailable.
I see. Are the hum/temp sensors part of your thermostats?
And why is the last thermostat (with _mode
suffix) available - what’s the difference?
The humid/temp comes from the ecobee which is the same device as climate_main_floor. I think the _mode ones change the thermostats to ECO mode, but do not control the actual thermostat temps.
All of this used to work fine before I updated hassio. Thanks for trying to help!
I am in the same boat, new code broke something with Ecobee.
I have the same problem. Is this being looked at?
This turned out to be my ecobee thermostat. It had lost it’s wifi connection. All is working now.
