I have also noticed that the climate controls in home assistant for the generic thermostat are in 0.5 increments but I can ask Google to change by 0.1.
I also can’t work out what the precision tag does in the config for the generic thermostat. The default value is 0.5 but it doesn’t change anything if I put 0.1 in this tag.
Did you setup a generic thermostat based on the nest thermostat or were you able to set the precision of the nest thermostat to 0.5 ? Because i didn’t setup any precision and mine seems to have a precision of 1.
I know this is an old thread, but I just wanted to know if anyone knows how to do the opposite and lock the default thermostat card to 1 degree C increments,
I have a Zwave to IR controller and the AirCon unit it operates only does 1 degree increments.
When I try to set a temperature using the thermostat, it allows 0.5 degree increments, but if I hit a half degree increment, it messes up the whole thing and sets the set temp to 10 degrees.
EG: I need to go from 24 to 22, but if I stop on 22.5 it will cause the whole thing to mess up.
