DrJohnM61
(John Maton)
January 8, 2024, 2:55pm
1
Since the latest update of HA, I am getting a message on the Thermostat card that the “Preset mode is not valid”
If I click on the three dots on the top right of the card and perform the same action, then no error message appears.
type: thermostat
entity: climate.wiser_gym
features:
- type: climate-hvac-modes
hvac_modes:
- auto
- heat
- 'off'
- type: climate-preset-modes
style: dropdown
preset_modes:
- Advance Schedule
- Cancel Overrides
- Boost 30m
- Boost 1h
- Boost 2h
- Boost 3h
show_current_as_primary: true
The action seems to work but now with this spurious error message
Core2024.1.2
Supervisor2023.12.0
Operating System11.3
Frontend20240104.0
Wiser Home Assistant Integration v3.4.2
I am having the same issue, did you find a fix?
DrJohnM61
(John Maton)
January 10, 2024, 9:25pm
3
No - same error line being produced when selecting from the drop down but seems to action the request. All my HACS and Add-ons are up to date so not sure what this can be
DrJohnM61
(John Maton)
January 10, 2024, 9:28pm
4
See also Drayton Wiser Home Assistant Integration - #3221 by msp1974
Seems it’s an issue with the front end integration. I am sure it will be fixed soon.
I have just moved to Drayton Wiser and I’m using the Thermostat Tile Cards. When I select a Preset I get this error but the Preset still works.
Anyone else still experiencing this error?
DrJohnM61
(John Maton)
December 21, 2024, 5:40am
6
Yes - still getting the same issue
JerryM
(JerryM)
December 21, 2024, 5:51am
7
1. Validate Preset Modes in Configuration
Ensure that the preset_modes
defined in your card exactly match those recognized by the backend integration. You can verify this by:
Checking the Developer Tools
→ States
for the entity climate.wiser_gym
. Look for the preset_modes
attribute and ensure the listed modes match your card configuration.
2. Modify the Thermostat Card Configuration
If the frontend does not fully support dropdowns for preset_modes
, you can simplify the configuration:
type: thermostat
features:
hvac_modes:
- auto
- heat
- 'off'
style: list
preset_modes:
- Advance Schedule
- Cancel Overrides
- Boost 30m
- Boost 1h
- Boost 2h
- Boost 3h
Changing style
to list
might work better if the dropdown implementation is causing issues.
3. Rebuild the Card
Sometimes, removing and recreating the card resolves configuration glitches.
4. Use a third party integration or HACS
If the default thermostat setup isn’t meeting your needs, you might want to explore third-party integrations. For example, I use
However, there are plenty of other thermostat options available that might suit your specific requirements.
From Developer Tools -> States
for climate.wiser_living_room
preset_modes: Advance Schedule, Cancel Overrides, Boost 30m, Boost 1h, Boost 2h, Boost 3h
The card with the dropdown list for Preset opened:
so they look like they match.
The card config is:
type: tile
entity: climate.wiser_living_room
features:
style: dropdown
- type: target-temperature
DrJohnM61
(John Maton)
December 21, 2024, 10:47am
9
Jerry, I have the following configuration:
type: thermostat
entity: climate.wiser_tv_room
features:
hvac_modes:
- auto
- heat
- "off"
style: dropdown
preset_modes:
- Advance Schedule
- Cancel Overrides
- Boost 30m
- Boost 1h
- Boost 2h
- Boost 3h
And the actions selected work (ie, I select Advance Schedule and the schedule advances), however, the following message pops up:
You can see that the actions match the pop-up so not sure why this pop-up is being presented. Prior to Jan 8th this year, the pop-up did not appear, so something changed.
RN-Say
(Rn Say)
December 21, 2024, 2:42pm
10
Same issue here. Functional card with the errant error message whose only job seems to be to get people to push the buttons again and again for a job that is already done. Nice!
