Whit the home assistant update 2021.6.6 to 2021.7.1 my thermostat split entity sensor
Whit 6.6 i have everything is in climate.xxx (temperature humidity etc) and its the only place it show
Whit 7.1 now i a have climtate.xxx whit temperature but no humidity information and new entity called sensor.xxx_local whit other information and humidity
Now i can’t have humidity and temperature in the same card ,mabe i do something wrong?
The thermostat is a stelpro SMT402 and is connected whit zigbee2mqtt,in lovelace i use simple thermostat to display temperature,humidity and ajustement
I double check my mqtt msg and nothing change.
Can i fix that or a have to stay on 2021.6.6 ?
On home assistant 2021.11.5 i manage to have temperature and humidity but the gui become realy slow and the console trow a lot of error
I attach some picture to show the entity before and afther
home assistant 6.6
The default card don’t use arrow to ajust the temp and I think I can add humidity.On the more recent version i was able to have both but juste like a say the console trow a lot of error and Lovelace was unstable ,I think it’s because of to different entity in the card (climate.xxx sensors.xxx)
I really want to be up to date but I don’t know how to fix this probleme or how to search for this on Google (I am a Google warrior )
I don’t understand why before 2021.6.6 all the mqtt msg was in one entity and now it separed,in the locked entity I have humidity and curent temp
My understanding is in a thermostat card you cannot add a lock feature and this is why Lovelace become unstable
At the time i wrote my reply a got a bunch of error… and lovelace become unresponsive.I delete everything and i start from scratch, i will see if a got the same error
