Thermostat + Homebridge?
I’ve got my Honeywell set up and working correctly, but I’d like to have homebridge find it so I can tell siri to “set inside temperature to 72 degrees” (or something like that).
Has anyone got these paired up? I’d love to know your configuration settings, if so. Thanks much
I don’t believe thermostats are supported yet in the homebridge-himeassistant plugin. Here is the list below. Alarm panels from Home Assistant aren’t supported either. Might be time for one of us to try and assist :slight_smile:
Binary Sensor - door, leak, moisture, motion, smoke, and window state
Cover - exposed as a garage door or window covering (see notes)
Fan - on/off/speed
Input boolean - on/off
Lights - on/off/brightness
Lock - lock/unlock lock
Media Players - exposed as an on/off switch
Scenes - exposed as an on/off switch
Sensors - carbon dioxide (CO2), humidity, light, temperature sensors
Switches - on/off
Found this: https://github.com/home-assistant/homebridge-homeassistant/issues/93
and this: https://github.com/tfresh1/homebridge-homeassistant/tree/add_climate
Seems like a reasonable starting point. Going to look at it tonight but I don’t honestly know what I’m doing (don’t tell my wife).
That definitely looks like a good start for the thermostat piece. There’s also an issue on there about alarm panels as well. I’d love to help out but I’m not even sure how to begin. One of the admins says it should be easy enough. I assume this holds for both the thermostat and alarm panels. If anyone has a quick start on doing this I’d be glad to help out and see if I can add one of these
