So in the heat of summer and the cool of winter, its pretty easy. I have 4 temp points that I put into node red that get set on varying conditions:
- No one home
- Someone one home
- Night time
- Wakeup
These work great and without fault. That is, until about now when outside temps can range between 40F and 80F in a given week.
Now, if the thermostat was last set to HEAT because we had a very chilly night, when we all leave the house the HEAT will get set to 76F. When in reality, this flow was meant to set the AC to 76F when we all leave the house.
How are you guys handling these weeks where you may need heat or AC on?
Right now I was thinking about implenting a flow where it checks the inside temp, checks the outside temp, and then make a decision based on those if the HEAT should be turned on or the AC should be. But was looking for how others are doing it.
