Thermostat max_temp from topic
I have a ZigBee TuYa X5H-GB-B thermostat that exposes max_temp as upper_temp. Home Assistant device state, min_temp and max_temp are set with constant values, so, how can I set max_temp with upper_temp attribute?
Scratching the surface, I need to set:
max_temp_template: '{{ value_json.upper_temp }}'
max_temp_topic: zigbee2mqtt/Termostato // friendly_name of device?
But:
Is an issue on Zigbee2Mqtt that not set the correct attribute?
Has Home Assistant support to automatically assign the max_temp with zigbee devices?
Can I tweak Home Assistant to do this?
Thanks in advanceā€¦
