Thermostat Min/Max Temperature vs Target Temperature
What is the difference between min/max temperature vs target temperature? Do you use them together or separately? My heater does not have any cooling capabilities, only heating so the hvac cool mode is useless to me, but the min max ranges only show up when using auto.
Do max temperature threshold mean after it goes above that it will turn on the cooling mode if possible, or that the heat will turn on until it reaches the max temperature?
Ideally what I want to create is the heater turns on until it reaches the max temp but then won’t turn back on again until it goes below the min temp to prevent it from turning on just to warm it up a single degree.
