I would like to add code to my automation that duplicates the ‘minus button’ on the thermostat card, but I cannot figure out how to do that. Does it have to be calculated from the preset temperature?
User service climate: set target temperature and set temperature to desired value.
Could you show me the yaml syntax?
sure
service: climate.set_temperature
temperature: 15
entity_id: climate.daria_bedroom_radiator_2
…and you could template the temperature to be current minus 0.5 (per the ‘minus’ button for example).
That’s actually what I would like to do. I already have the following, but I would like to replace the ‘18.5’ with (temperature - 0.5):
alias: Thermostat regulation 21.5
description: Adjust Temperature
- platform: numeric_state
entity_id:
- sensor.master_bedroom_temperature
above: 21.5
condition:
- condition: state
entity_id: climate.master_bedroom
state: heat
- service: climate.set_temperature
metadata: {}
temperature: 18.5
area_id: living_room
mode: single
In my opinion this is pointless. Human body can’t sense temperature difference of 0.5 degrees. Probably can’t even sense a difference for a 1 degree.
My zoning isn’t working correctly at the moment, so this is hopefully a temporary patch. In any case, I am looking for yaml help.
I tried
temperature: {{ sensor.living_room_temperature - 1 }}```
but I end up with
temperature:
“[object Object]”: null
Why? Are you using temperature sensor on trv? If that is the case don’t use it like that.
Use better thermostat integration as you can on the fly calibrate trv temperature using in room temperature sensor.
OK. Now how do I do it in yaml?
Something like this:
temperature: "{{ state_attr('climate.master_bedroom','target_temp')|float(18) -0.5 }}"
note:
- float(18) is the default value when the entity is available - change that number to what you would like the default to be.
- I’m not sure if
target_temp
is the right one - you will need ti check this by going to
Developer tools ➜ states, typing inclimate.master_bedroom
and looking under the listed attributes for that entity,
Thank you! This is exactly what I was looking for. I modified the line:
temperature: "{{ state_attr('climate.living_room','temperature')|float(18) -0.5 }}"
Where can I learn this syntax?
Glad it worked,
Regarding templating, you can start here,
