Hello i am using thermostat generic with the following configuration . i am using broadlink to send the ir commands to my air condition
platform: generic_thermostat
heater: climate.living_room
target_sensor: sensor.wi_fi_universal_remote_temperature
min_temp: 25
max_temp: 27
ac_mode: true
target_temp: 26
cold_tolerance: 0
hot_tolerance: 0.3
min_cycle_duration:
seconds: 1
keep_alive:
minutes: 5
initial_hvac_mode: “off”
away_temp: 29
when i am using it the thermostat stops at 24 not on the 25 as the min temp and if i am change it the keep alive to 60 minutes doesnt not trigger to stop the ac . for me the 5 minutes is pain in the ass because as i am sleeping i here the beep beep from the alive .
Could some help me how to set it up correctly . if i need some other configuration to be sharp on my temps ? thank you .
