My CT101 thermostat has recently (last 3 days) randomly started to become unavailable in ZwaveJS. No change were made to my HA instance or the thermostat itself. It’s mains powered so battery is not in play here.
A ping from zwave will wake the device up and it will then become available for an undetermined amount of time. A few hours, a day…I never know. It eventually fails again though. This is becoming a problem with cooling the house on schedule because my automations are failing when it’s unavailable.
This is what I"m seeing in the ZwaveJS Logs:
2023-05-08T23:15:02.591Z CNTRLR [Node 004] Mapping unsolicited report from root device to endpoint #1
2023-05-08T23:15:02.606Z CNTRLR [Node 004] Mapping unsolicited report from root device to endpoint #1
2023-05-08T23:30:59.361Z CNTRLR [Node 004] did not respond after 1/3 attempts. Scheduling next try in 500 ms.
2023-05-08T23:31:00.134Z CNTRLR [Node 004] did not respond after 2/3 attempts. Scheduling next try in 500 ms.
2023-05-08T23:31:00.880Z CNTRLR [Node 004] The node did not respond after 3 attempts, it is presumed dead
2023-05-08T23:31:00.881Z CNTRLR [Node 004] The node is now dead.
Z-Wave error ZWaveError: Failed to send the command after 3 attempts (Status NoAck) (ZW0204)
at Driver.sendMessage (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:4196:23)
at Driver.sendCommandInternal (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:4389:28)
at Driver.sendCommand (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:4500:15)
at ThermostatSetpointCCAPI.set (/usr/src/node_modules/@zwave-js/cc/src/cc/ThermostatSetpointCC.ts:229:24)
at Proxy.ThermostatSetpointCCAPI.<computed> (/usr/src/node_modules/@zwave-js/cc/src/cc/ThermostatSetpointCC.ts:148:29)
at ZWaveNode.setValue (/usr/src/node_modules/zwave-js/src/lib/node/Node.ts:969:29)
at NodeMessageHandler.handle (/usr/src/node_modules/@zwave-js/server/dist/lib/node/message_handler.js:23:38)
at Object.node (/usr/src/node_modules/@zwave-js/server/dist/lib/server.js:41:96)
at Client.receiveMessage (/usr/src/node_modules/@zwave-js/server/dist/lib/server.js:106:99)
at WebSocket.<anonymous> (/usr/src/node_modules/@zwave-js/server/dist/lib/server.js:50:45) {
code: 204,
context: SendDataRequestTransmitReport {
host: [Driver],
type: 0,
functionType: 19,
payload: <Buffer ba 01>,
_callbackId: 186,
transmitStatus: 1,
txReport: undefined
transactionSource: ' at Driver.sendMessage (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:4196:23)\n' +
' at Driver.sendCommandInternal (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:4389:28)\n' +
' at Driver.sendCommand (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:4500:15)\n' +
' at ThermostatSetpointCCAPI.set (/usr/src/node_modules/@zwave-js/cc/src/cc/ThermostatSetpointCC.ts:229:24)\n' +
' at Proxy.ThermostatSetpointCCAPI.<computed> (/usr/src/node_modules/@zwave-js/cc/src/cc/ThermostatSetpointCC.ts:148:29)\n' +
' at ZWaveNode.setValue (/usr/src/node_modules/zwave-js/src/lib/node/Node.ts:969:29)\n' +
' at NodeMessageHandler.handle (/usr/src/node_modules/@zwave-js/server/dist/lib/node/message_handler.js:23:38)\n' +
' at Object.node (/usr/src/node_modules/@zwave-js/server/dist/lib/server.js:41:96)\n' +
' at Client.receiveMessage (/usr/src/node_modules/@zwave-js/server/dist/lib/server.js:106:99)\n' +
' at WebSocket.<anonymous> (/usr/src/node_modules/@zwave-js/server/dist/lib/server.js:50:45)'
Any help would be appreciated. Reboot of HA and of the host (Rpi 4 with HUSBZB-1 controller) hasn’t made any difference.
