Please see below.
"home_assistant": {
"installation_type": "Home Assistant OS",
"version": "2024.4.4",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.12.2",
"docker": true,
"arch": "aarch64",
"timezone": "America/Los_Angeles",
"os_name": "Linux",
"os_version": "6.6.25-haos",
"supervisor": "2024.04.4",
"host_os": "Home Assistant OS 12.2",
"docker_version": "25.0.5",
"chassis": "embedded",
"run_as_root": true
"custom_components": {},
"integration_manifest": {
"domain": "zwave_js",
"name": "Z-Wave",
"codeowners": [
"@home-assistant/z-wave"
"config_flow": true,
"dependencies": [
"http",
"repairs",
"usb",
"websocket_api"
"documentation": "https://www.home-assistant.io/integrations/zwave_js",
"integration_type": "hub",
"iot_class": "local_push",
"loggers": [
"zwave_js_server"
"quality_scale": "platinum",
"requirements": [
"pyserial==3.5",
"zwave-js-server-python==0.55.3"
"usb": [
"vid": "0658",
"pid": "0200",
"known_devices": [
"Aeotec Z-Stick Gen5+",
"Z-WaveMe UZB"
"vid": "10C4",
"pid": "8A2A",
"description": "*z-wave*",
"known_devices": [
"Nortek HUSBZB-1"
"zeroconf": [
"_zwave-js-server._tcp.local."
"is_built_in": true
"data": {
"versionInfo": {
"driverVersion": "12.5.5",
"serverVersion": "1.35.0-beta.1",
"minSchemaVersion": 0,
"maxSchemaVersion": 35
"entities": [
"domain": "light",
"entity_id": "light.thermostat_basic",
"original_name": "Basic",
"original_device_class": null,
"disabled": false,
"disabled_by": null,
"hidden_by": null,
"original_icon": null,
"entity_category": null,
"supported_features": 0,
"unit_of_measurement": null,
"value_id": "4-32-0-currentValue",
"primary_value": {
"command_class": 32,
"command_class_name": "Basic",
"endpoint": 0,
"property": "currentValue",
"property_name": "currentValue",
"property_key": null,
"property_key_name": null
"state": {
"nodeId": 4,
"index": 0,
"status": 4,
"ready": true,
"isListening": true,
"isRouting": true,
"isSecure": false,
"manufacturerId": 8,
"productId": 32,
"productType": 7,
"firmwareVersion": "0.8",
"name": "Thermostat",
"deviceConfig": {
"filename": "/data/db/devices/0x0008/wdtc-20.json",
"isEmbedded": true,
"manufacturer": "Wayne Dalton",
"label": "WDTC-20",
"description": "Thermostat",
"devices": [
"productType": 7,
"productId": 32
"firmwareVersion": {
"min": "0.0",
"max": "255.255"
"preferred": false
"label": "WDTC-20",
"interviewAttempts": 0,
"isFrequentListening": false,
"maxDataRate": 40000,
"supportedDataRates": [
40000
"protocolVersion": 2,
"supportsBeaming": true,
"supportsSecurity": false,
"nodeType": 1,
"deviceClass": {
"basic": {
"key": 4,
"label": "Routing Slave"
"generic": {
"key": 8,
"label": "Thermostat"
"specific": {
"key": 6,
"label": "General Thermostat V2"
"mandatorySupportedCCs": [
32,
114,
64,
67,
134
"mandatoryControlledCCs": []
"interviewStage": "Complete",
"deviceDatabaseUrl": "https://devices.zwave-js.io/?jumpTo=0x0008:0x0007:0x0020:0.8",
"statistics": {
"commandsTX": 1,
"commandsRX": 0,
"commandsDroppedRX": 0,
"commandsDroppedTX": 0,
"timeoutResponse": 0,
"rtt": 350.1,
"lastSeen": "2024-05-06T16:18:21.950Z",
"rssi": -80,
"lwr": {
"protocolDataRate": 2,
"repeaters": [],
"rssi": -80,
"repeaterRSSI": []
"highestSecurityClass": -1,
"isControllerNode": false,
"keepAwake": false,
"values": {
"4-32-0-currentValue": {
"endpoint": 0,
"commandClass": 32,
"commandClassName": "Basic",
"propertyName": "currentValue",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Current value",
"min": 0,
"max": 99,
"stateful": true,
"secret": false
"value": 0
"4-32-0-targetValue": {
"endpoint": 0,
"commandClass": 32,
"property": "targetValue",
"propertyName": "targetValue",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": true,
"label": "Target value",
"min": 0,
"max": 255,
"stateful": true,
"secret": false
"value": 0
"4-32-0-duration": {
"endpoint": 0,
"commandClass": 32,
"property": "duration",
"propertyName": "duration",
"ccVersion": 1,
"metadata": {
"type": "duration",
"readable": true,
"writeable": false,
"label": "Remaining duration",
"stateful": true,
"secret": false
"4-32-0-restorePrevious": {
"endpoint": 0,
"commandClass": 32,
"property": "restorePrevious",
"propertyName": "restorePrevious",
"ccVersion": 1,
"metadata": {
"type": "boolean",
"readable": false,
"writeable": true,
"label": "Restore previous value",
"states": {
"true": "Restore"
"stateful": true,
"secret": false
"4-114-0-manufacturerId": {
"endpoint": 0,
"commandClass": 114,
"commandClassName": "Manufacturer Specific",
"property": "manufacturerId",
"propertyName": "manufacturerId",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Manufacturer ID",
"min": 0,
"max": 65535,
"stateful": true,
"secret": false
"value": 8
"4-114-0-productType": {
"endpoint": 0,
"property": "productType",
"propertyName": "productType",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Product type",
"min": 0,
"max": 65535,
"stateful": true,
"secret": false
"value": 7
"4-114-0-productId": {
"endpoint": 0,
"property": "productId",
"propertyName": "productId",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Product ID",
"min": 0,
"max": 65535,
"stateful": true,
"secret": false
"value": 32
"4-134-0-libraryType": {
"endpoint": 0,
"commandClass": 134,
"commandClassName": "Version",
"property": "libraryType",
"propertyName": "libraryType",
"ccVersion": 1,
"metadata": {
"type": "number",
"readable": true,
"writeable": false,
"label": "Library type",
"states": {
"0": "Unknown",
"1": "Static Controller",
"2": "Controller",
"3": "Enhanced Slave",
"4": "Slave",
"5": "Installer",
"6": "Routing Slave",
"7": "Bridge Controller",
"8": "Device under Test",
"9": "N/A",
"10": "AV Remote",
"11": "AV Device"
"stateful": true,
"secret": false
"value": 6
"4-134-0-protocolVersion": {
"endpoint": 0,
"property": "protocolVersion",
"propertyName": "protocolVersion",
"ccVersion": 1,
"metadata": {
"type": "string",
"readable": true,
"writeable": false,
"label": "Z-Wave protocol version",
"stateful": true,
"secret": false
"value": "2.78"
"4-134-0-firmwareVersions": {
"endpoint": 0,
"property": "firmwareVersions",
"propertyName": "firmwareVersions",
"ccVersion": 1,
"metadata": {
"type": "string[]",
"readable": true,
"writeable": false,
"label": "Z-Wave chip firmware versions",
"stateful": true,
"secret": false
"value": [
"0.8"
"endpoints": {
"0": {
"nodeId": 4,
"index": 0,
"deviceClass": {
"basic": {
"key": 4,
"generic": {
"key": 8,
"specific": {
"key": 6,
32,
114,
64,
67,
134
"commandClasses": [
"id": 32,
"name": "Basic",
"version": 1,
"isSecure": false
"id": 114,
"name": "Manufacturer Specific",
"version": 1,
"isSecure": false
"id": 134,
"name": "Version",
"version": 1,
"isSecure": false
