Thermostat showing 2 values
i recently moved and my new place in installed a centralite 3 thermostat. in my previous place i had a zwave. i used zwavejs2mqtt and the thermostat device came up no problem in HA.
Now with the centralite it’s detected but not sure I am seeing 2 temp values. I know normally in auto mode you would set a max and min temp values.
Not sure how I go about setting the temp now.
On my previous thermostat I could move the slider and it was just the temperature set value. Now it looks like it’s a range.
Any suggestions? thanks!
I am guessing that the range is cool_setpoint and heat_setpoint but if I am on “heat” as you see by the fire icon. Why does it show the range still? Is there something that I have different than the normal thermostat example on the HA site?
