I have several TV05-ZG running with ZHA. I
just noticed that the devices change the target temperature looking at the graphs. I’ve not changed the temperature myself and I have no clue what to do. I restarted the system already but this did not help. Anybody an idea what I can do, so that the target temperature does not change itself?
After manual reset of all thermostats the target temperature does not change itself. I guess there was some internal schedule, which was not shown in home assistant.
That’s what i’ve done, too. But after that betterthermostat does not work anymore. And i have no idea how to fix this. I deleted and reinstalled, but nothing changes. The logs say it waits for something to appear, but it does not appear.
I’m coming from FHEM and i thought HA would be much easier. I fact it is the opposite. A black box with tons of sideeffect.
the custom quirk has nothing to do with betterthermostat.
It only solves the problem that the thermostats change the temperature.
Put simply, betterthermostat obtains its values from a normal thermostat in combination with an additional temperature sensor.
Do your regular thermostats with the custom quirk permanently deliver the correct values?
If this is the case, betterthermostat should also derive correct values from this.
I recognize the problems mentioned. I now have 7 thermostats working with some simple automation. I have also added a heat demand bridge so that each thermostat generates its own heat demand and you can therefore regulate the heat per room.
