I’m confused about some of the parameters for working with climate control thermostats. When calling set_temperature
there are two optional values that I’m unsure about. What do the values for target_temp_high
and target_temp_low
do and why would I set them?
My goal is to just set the mode to Auto
and change the temperature setpoints based on forecasted high and low temps for the day. Is there a way to control the range that the system flips between cool and heat? I am using the in-development Honeywell Lyric integration here. I am curious about others’ experience with the Auto mode feature of a thermostat.
