I have a problem with the climate module in Home Assistant in order to do a thermostat for my bathroom heater.
I have a room temperature of 19.6°C and in order to test my setup, I have choose a target at 26°C, but nothing happen, the heater switch doesn’t turn on…
Here is my code :
- platform: mqtt
name: "Salle de Bain Température"
state_topic: "tele/RadSDB2/SENSOR"
value_template: '{{ value_json.SI7021.Temperature }}'
unit_of_measurement: "°C"
availability_topic: "tele/RadSDB2/LWT"
payload_available: "Online"
payload_not_available: "Offline"
switch:
- platform: mqtt
command_topic: "cmnd/RadSDB1/power"
state_topic: "stat/RadSDB1/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
- platform: mqtt
command_topic: "cmnd/RadSDB2/power"
state_topic: "stat/RadSDB2/POWER"
qos: 1
payload_on: "ON"
payload_off: "OFF"
retain: true
# Thermostat Salle de Bain
climate:
- platform: generic_thermostat
heater: switch.RadSDB1
target_sensor: sensor.sdb_temperature
min_temp: 15
max_temp: 28
ac_mode: false
target_temp: 27
cold_tolerance: 0.3
hot_tolerance: 0
min_cycle_duration:
seconds: 5
keep_alive:
minutes: 3
away_temp: 16
precision: 0.1
Do you have any idea of what I have done wrong ?
