Thermostat without switch
Guys, I am getting crazy and need your help. I do have a heat pump (Nibe) where I can see the actual room temperature, where I can set the target temperature for cooling mode and target temperature for heating mode. Furthermore I can trigger a one-time increase of warm water.
So, what I am looking for is like the thermostat card, where I can see the actual room temperature and where I can see the target temperature.
Room temperature is coming from a sensor (via the heat pump) and target temperature is the value sent to the heat pump. If there would be even a switch to trigger the increase of warm water, that would be fabulous.
With the generic thermostat it is not working as it requires the “heater”.
Any ideas or suggestions?
thx
I think you are looking for this, it is a shame HA has no native fully functional template climate entity:
With this, standard thermostat cards can use the entity.
Thanks @Edwin_D , that looks pretty promising. Now it is getting a little embarrissing, but how do I get this into my HASS? I do not find it in HACS nor can I use it as custom repositiry.
No need for embarassment. I had only bookmarked it in case I needed it, but have 't used it myself. You are the first to point out is is not configured for hacs, not is it giving installation instructions. So I guess I would need to Google how to manually install too :slight_smile:
