Kevin85
(Kevin)
August 28, 2024, 9:57am
1
Hello everyone,
i want to create a virtual thermostat in HA but i can’t select the correct item to use a s switch.
My switch object is a NodOn SIN 4-1-20 zigbee
When i create the virtual thermostat, i can’t choose it
Does i’m doing something wrong or is ther another method to do it ?
Thx
Kevin85
(Kevin)
August 29, 2024, 3:32pm
2
I finally find that my device has a device_class as ‘light’ and the basic thermostat need ‘switch’ or ‘FAN’ device_class.
It’s possible to change the device_class of my device or to add ‘light’ device-Class to Basic Thermostat ?
Hellis81
(Hellis81)
August 29, 2024, 3:46pm
3
Perhaps something went wrong when pairing the switch.
I would try and reset the device, remove it from HA and re-pair it.
Kevin85
(Kevin)
August 29, 2024, 4:48pm
4
I already dit it three times but nothing change
You can create a Template Switch in the Helper menu which will create a switch
entity that can be used for what you are doing.
Kevin85
(Kevin)
August 29, 2024, 5:17pm
6
Many thanks, i got it working !
