I am a fresh Home Assistant user and so far, all is going well.
I have set up a few devices including Devolo radiator thermostats.
They show up fine in the frontend and I can control everything as expected.
However, I am trying to use the homekit integration and for some reason, the thermostats don’t show up.
ocnfiguration yaml looks like this
homekit:
filter:
include_domains:
- sensor
- climate
- switch
- light
include_entities:
- climate.danfoss_devolo_home_control_radiator_thermostat_heating_1
- sensor.danfoss_devolo_home_control_radiator_thermostat_temperature
- sensor.danfoss_devolo_home_control_radiator_thermostat_battery_level
all lights and switches show up fine in homekit but the thermostat does not…
I double-checked for typos, checked the yaml file format and everything.
Do I have to specify anything for the entitiy to make homekit recognize it? Does anyone have an example? at first I thought, simply adding the “climate” domain was enough, but no. Then I added the specific entities but still no luck…
thank you for any advice
