ThingSpeak configuration help:
I entered the configuration in the configuration.yaml file
thingspeak:
api_key: OOOXXXXKEY WRITE
whitelist: sensor.Sonda_Alta_temperature
but I don’t see the entity the channel is private and there are two fields
Does the component need to be installed? If so, how should I do?
