Think I have my duckdns config wrong
Here is my config file. It was working but does not any more. Any idea what I have missing/wrong?
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
  themes: !include_dir_merge_named themes
# Text to speech
tts:
  - platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
# BRE 12/6/2023 from here
http:
  ssl_certificate: /ssl/fullchain.pem
  ssl_key: /ssl/privkey.pem
google_assistant:
  project_id: homeassistant-58874
  service_account: !include SERVICE_ACCOUNT.JSON
  report_state: true
homeassistant:
  external_url: https://xxxx.duckdns.org:8123
  internal_url: http://192.168.0.10:8123
climate:
  - platform: generic_thermostat
    heater: switch.2_fan
    target_sensor: sensor.h5075_0b91_temperaturen
    max_temp: 40
    min_temp: 10
    ac_mode: true
    target_temp: 23
    cold_tolerance: 0
    hot_tolerance: 1
    initial_hvac_mode: "off"
    away_temp: 25.5
    precision: 0.1
logger:
  default: warning
  logs:
    custom_components.adaptive_lighting: debug
What or how does it not work anymore?
It works fine on mobile but not on desktop (and I am hard-wired into same network)
Is it http://homeassistant.local:8123 or http://192.168.0.10:8123 that does not work?
or both?
What URL/IP address is listed on the HA server output, when you connect a monitor to it?
