After upgrading to 064.1 it seems to be something wrong with Thiningcleaner platform.
2018-03-01 21:12:00 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform thinkingcleaner
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 84, in async_setup
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/local/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
return fut.result()
File "/usr/local/lib/python3.6/asyncio/futures.py", line 243, in result
raise self._exception
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/sensor/thinkingcleaner.py", line 59, in setup_platform
devices = discovery.discover()
File "/srv/homeassistant/lib/python3.6/site-packages/pythinkingcleaner/discovery.py", line 12, in discover
data = response.json()
File "/srv/homeassistant/lib/python3.6/site-packages/requests/models.py", line 892, in json
return complexjson.loads(self.text, **kwargs)
File "/usr/local/lib/python3.6/json/__init__.py", line 354, in loads
return _default_decoder.decode(s)
File "/usr/local/lib/python3.6/json/decoder.py", line 339, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/local/lib/python3.6/json/decoder.py", line 357, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
