Hi there,
I have Home Assistant 0.42.3 running on a Raspberry Pi 3 with Hassbian. I’m using the ThinkingCleaner component to control my Roomba robot hoover. After upgrading to 0.42.3 i noticed some errors from the component in the log. The ThinkingCleaner (both switch and sensor) are not showing up in the frontend.
17-04-14 00:53:03 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform thinkingcleaner
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 345, in _make_request
self._validate_conn(conn)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 844, in _validate_conn
conn.connect()
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connection.py", line 326, in connect
ssl_context=context)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/util/ssl_.py", line 324, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
File "/usr/lib/python3.4/ssl.py", line 364, in wrap_socket
_context=self)
File "/usr/lib/python3.4/ssl.py", line 577, in __init__
self.do_handshake()
File "/usr/lib/python3.4/ssl.py", line 804, in do_handshake
self._sslobj.do_handshake()
ssl.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:600)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/adapters.py", line 423, in send
timeout=timeout
File "/srv/homeassistant/lib/python3.4/site-packages/requests/packages/urllib3/connectionpool.py", line 630, in urlopen
raise SSLError(e)
requests.packages.urllib3.exceptions.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:600)
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 153, in _async_setup_platform
entity_platform.schedule_add_entities, discovery_info
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/sensor/thinkingcleaner.py", line 61, in setup_platform
devices = discovery.discover()
File "/home/homeassistant/.homeassistant/deps/pythinkingcleaner/discovery.py", line 11, in discover
response = requests.get(url=DISCOVERY_URL)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/api.py", line 70, in get
return request('get', url, params=params, **kwargs)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/api.py", line 56, in request
return session.request(method=method, url=url, **kwargs)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/sessions.py", line 488, in request
resp = self.send(prep, **send_kwargs)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/sessions.py", line 609, in send
r = adapter.send(request, **kwargs)
File "/srv/homeassistant/lib/python3.4/site-packages/requests/adapters.py", line 497, in send
raise SSLError(e, request=request)
requests.exceptions.SSLError: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:600)
I have my frontend running on HTTPS with a certificate generated by Let’s Encrypt (Certbot), but I don’t think that’s related. I checked the pythinkingcleaner that I believe is being used and it seems to use the address http://[IP-of-Roomba]/ (with not https). I verified that my roomba is in fact running on the IP address and I can send JSON commands to it without problems.
I don’t know which certificate it’s failing to verify. Can anybody offer some help?
