As a newbie and trying to do the correct research, all I have read say that Thrid Reality devices easily intergrate into HA.
I am using HA Green with Zigbee ZHA. I have a simple Thrid Reality door sensor I want to install. The light flashes blue however is never fround in my Zigbee.
Can anyone explain what I am doing wrong? Most all I read does not require a hub.
Remove the cover, hold the button down until the LED turns bright solid red (RESET), then release. The button in a few seconds should flash blue, and then you initiate the ZHA pairing.
