Third Reality Smart Button (Model: 3RSB22BZ) - Configurable Automation
Originally looked at this automation, but it only supported buttons setup using ZHA, not Z2M. So here we are! This blueprint gives you an automation template to select any* button exposed as an event entity with an event_type attribute. Theoretically works outside of Z2M as well, but I haven’t been able to test other buttons that work in a similar fashion.
As stated on the aforementioned blueprint post, “this blueprint fires from the single , double , and hold events”. Here’s the yaml for your perusal:
blueprint:
  name: Third Reality Button - Multi-Action
  description: >
    Trigger three configurable actions from a single button entity based on
    single press, double press, and hold event types. Originally designed for
    Third Reality button model 3RSB22BZ set up in Zigbee2MQTT.
    Should work for buttons exposing event entities with event_type attributes.
  domain: automation
  input:
    button_entity:
      description: The event entity for your button.
      selector:
        entity:
          domain: event
    action_single:
      name: Single Press Action
      description: Action(s) to run when the button is pressed once.
      default: []
      selector:
        action: {}
    action_double:
      name: Double Press Action
      description: Action(s) to run when the button is pressed twice.
      default: []
      selector:
        action: {}
    action_hold:
      description: Action(s) to run when the button is held down.
      default: []
      selector:
        action: {}
mode: single
triggers:
  - trigger: state
    entity_id: !input button_entity
conditions: []
actions:
  - choose:
      - conditions:
          - condition: state
            attribute: event_type
            state: single
        sequence: !input action_single
      - conditions:
          - condition: state
            state: double
        sequence: !input action_double
      - conditions:
          - condition: state
            state: hold
        sequence: !input action_hold
Hope this works for other buttons out there! Open to suggestions so feel free to scream at me below. :stuck_out_tongue:
*: only tested and verified with the above listed button configured via Zigbee2MQTT
UPDATE - May 05, 2026
  • Updated to use the MQTT device directly due to false-triggers via event entities
  • Checking explicitly for each trigger type, using trigger ids for handling each action
  • Added release action
blueprint:
  name: Third Reality Button - Z2M Multi-Action
  description: >
    Trigger three configurable actions from a single button MQTT device based on
    single press, double press, hold, and release actions. Originally designed for Third Reality button model 3RSB22BZ set up in Zigbee2MQTT.
  domain: automation
  input:
    button_device:
      description: The MQTT device for your button.
      selector:
        device:
    action_single:
      description: Action to run when the button is pressed once.
      default: []
      selector:
    action_double:
      description: Action to run when the button is pressed twice.
      default: []
      selector:
    action_hold:
      description: Action to run when the button is held down.
      default: []
      selector:
    action_release:
      description: Action to run when the button is released.
      default: []
      selector:
mode: single
triggers:
  - domain: mqtt
    device_id: !input button_device
    type: action
    subtype: single
    trigger: device
  - domain: mqtt
    type: action
    subtype: double
    trigger: device
  - domain: mqtt
    type: action
    subtype: hold
    trigger: device
  - domain: mqtt
    type: action
    subtype: release
    trigger: device
conditions: []
actions:
  - choose:
      - conditions:
          - condition: trigger
      - conditions:
      - conditions:
      - conditions:
        sequence: !input action_release
Leaving the original for posterity. Also can’t edit the post I guess.
@mitchnemirov Worked like a charm! Thanks so much!
The blueprint worked perfectly but I am just getting stared with home assistant and seems weird to me to need to do it this way. But I am coming from SmartThings and am use to installing edge drivers to get access to advanced settings. So maybe this is no different?
