Is there a way to let me know if the power of the freezer is off?
Can someone point me to the correct automation for this idea?
What a great software package this HA is
If the power to that outlet is off or the smart switch dies, then the states of all of those entities will likely go to unavailable or unknown.
If something happen to the freezer itself you will see changes to the pattern of power consumption. You will need to let it run for at least a couple days so you can determine what is normal.
I was hoping that if the power went off and then came back on an hour later the switch would remain in the on position. Right now it looks like the freezer is use 0.5 kWh per day, Would it be a good idea to say if the power switch uses less than 0.1 kWh per day then notify me? Is that the normal way of not losing a freezer full of meat?
Sad, this switch doesnât have the start-up behavior option. I just unplugged the plug and plugged it back in again and the plug was in the disconnected position.
Thanks for your help!
I have the Gen1 version of the switch, and the ThirdReality website says âThird Reality Smart Plug is a simple solution to make the intelligence appliances smarter, like lights, fans, coffee makers and more. After the update, Smart Plug Gen2 keeps all former features and upgrade with real-time power monitoring and restore status.â, so I canât imagine that they took away a feature.
But I donât seem to be getting anywhere with setting the startup_on_off flag. Iâve tried several versions of value:1 etc but it isnât triggering
Can anyone offer any pointers as to why the off_wait_time (id: 0x4002) doesnât appear on the older HA and is there a work around to manually set the value?
I tried pre-setting the plug under the new HA but when I re-register the plug to the old version of HA it deletes the startup default settings
Likely the hardware engineers who designed the plug probably choose the simplest (hence cheapest) way to get the measurements.
Hence internally the plug probably has the equivalent of an internal Voltmeter and Ammeter, hence its possible to measure the instantaneous:
Voltage.
Current
Power (via multiplication V * I)
Energy is the integral of power over time, most likely the circuitry samples the Voltage and Current, x times per minute and simply sums power to get total energy consumption.
Its likely that the internal calculation has a higher polling frequency than the frequency that the device reports updates over Zigbee so unless you can find a spec sheet that states the internal polling frequency (which is unlikely to be exposed via Zigbee) your only other option is to try some physical tests in order to estimate the internal polling frequency.
Just did a quick test, with a Gen2 plug using Z2M:
The plug seems to be sending Zigbee updates around every 5 seconds.
With a 12 amp draw (118v) the power rating is only given to 2 decimal places so it only changes approximately every 30 seconds (due to precision).
So I donât think most people need to care about internal vs external polling rates.
