Hey everyone so I’m going a bit crazy here. I am attempting to install Node-RED version 13.4 on a 32GB Pi 4 64-bit using this guide on Windows 10 but having issues accessing the configuration tab in the add-on store, and the install itself is not working. When I hit “start” and then click the node-red tab in the sidebar, I get a 502 bad gateway. Everything is saying the fix is changing ssl to false and adding secret_credentials in the “Configuration” tab, but I can’t do that because on the add-on page’s configuration tab, it simply says “This add-on does not expose configuration for you to mess with…” no matter how many times I reinstall the add-on or restart HA entirely. I’ve watched multiple tutorials on YouTube, but it seems like no one else has this problem with the “Configuration” tab on the add-on store.
EDIT
Also, I tried to find the /config/node-red folder with File Editor like the documentation recommends but it apparently doesn’t exist, there is no folder in /config with anything close to the name node-red.
thanks folks
