This if getting annoying! tried updating hassio lost GUI
Hi all,
Just tried updating Hassio from 77.3 to 79.2 and the update didn’t happen. It just made my UI disappear. Again.
This has happened lots of time now.
These are my SU logs. Is there any info in here that any of you ninjas can help me with???:
core-ssh:~# hassio su logs
Error decoding json invalid character 'r' looking for beginning of value:     req, traces, timeout)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 879, in _create_direct_connection
    raise last_exc
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 862, in _create_direct_connection
    req=req, client_error=client_error)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 829, in _wrap_create_connection
    raise client_error(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused]
18-10-02 09:51:54 ERROR (MainThread) [aiohttp.server] Unhandled exception
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 410, in start
    await resp.prepare(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_response.py", line 300, in prepare
    return await self._start(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_response.py", line 608, in _start
    return await super()._start(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_response.py", line 367, in _start
    await writer.write_headers(status_line, headers)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/http_writer.py", line 110, in write_headers
    self._write(buf)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/http_writer.py", line 67, in _write
    raise ConnectionResetError('Cannot write to closing transport')
ConnectionResetError: Cannot write to closing transport
18-10-02 09:51:59 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<WebSocketWriter.ping() done, defined at /usr/local/lib/python3.7/site-packages/aiohttp/http_websocket.py:617> exception=RuntimeError('unable to perform operation on <TCPTransport closed=True reading=False 0x71883dc0>; the handler is closed')>
  File "/usr/local/lib/python3.7/site-packages/aiohttp/http_websocket.py", line 621, in ping
    return await self._send_frame(message, WSMsgType.PING)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/http_websocket.py", line 603, in _send_frame
    self.transport.write(header + message)
  File "uvloop/handles/stream.pyx", line 671, in uvloop.loop.UVStream.write
  File "uvloop/handles/handle.pyx", line 159, in uvloop.loop.UVHandle._ensure_alive
RuntimeError: unable to perform operation on <TCPTransport closed=True reading=False 0x71883dc0>; the handler is closed
18-10-02 09:51:59 INFO (MainThread) [hassio.api.proxy] Home-Assistant Websocket API request initialze
18-10-02 09:51:59 INFO (MainThread) [hassio.api.proxy] Websocket access from a0d7b954_appdaemon3
18-10-02 09:51:59 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 822, in _wrap_create_connection
    return await self._loop.create_connection(*args, **kwargs)
  File "uvloop/loop.pyx", line 1881, in create_connection
  File "uvloop/loop.pyx", line 1860, in uvloop.loop.Loop.create_connection
ConnectionRefusedError: [Errno 111] Connection refused
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 390, in start
    resp = await self._request_handler(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 352, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 106, in impl
    return await handler(request)
  File "/usr/local/lib/python3.7/site-packages/hassio/api/security.py", line 80, in token_validation
  File "/usr/local/lib/python3.7/site-packages/hassio/api/proxy.py", line 210, in websocket
    client = await self._websocket_client()
  File "/usr/local/lib/python3.7/site-packages/hassio/api/proxy.py", line 120, in _websocket_client
    url, heartbeat=60, verify_ssl=False)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 605, in _ws_connect
    proxy_headers=proxy_headers)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 370, in _request
    timeout=timeout
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 445, in connect
    proto = await self._create_connection(req, traces, timeout)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 757, in _create_connection
    raise last_exc
18-10-02 09:51:59 ERROR (MainThread) [aiohttp.server] Unhandled exception
    self._write(buf)
18-10-02 09:52:04 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<WebSocketWriter.ping() done, defined at /usr/local/lib/python3.7/site-packages/aiohttp/http_websocket.py:617> exception=RuntimeError('unable to perform operation on <TCPTransport closed=True reading=False 0x7187a030>; the handler is closed')>
RuntimeError: unable to perform operation on <TCPTransport closed=True reading=False 0x7187a030>; the handler is closed
18-10-02 09:52:04 WARNING (MainThread) [hassio.api.security] /supervisor/logs no role for core_ssh
18-10-02 09:52:04 INFO (MainThread) [hassio.api.proxy] Home-Assistant Websocket API request initialze
18-10-02 09:52:04 INFO (MainThread) [hassio.api.proxy] Websocket access from a0d7b954_appdaemon3
