the hassio install script fails to connect with the docker daemon after:
[info] Install supervisor Docker container
Anyone have any ideas why?
Sounds like it failed to install the hass.io supervisor docker. Did you run the command as root user?
You need to go sudo -s
If the command prompt ends in $ you are not root. Root ends in #.
After a failed HASSIO upgrade from 0.85 to 0.85.1 (was working perfectly in 0.85, pressing 0.85.1 update button innside HASS disconnected the client but nothing happened) I started to reinstall all and followed the instructions by the letter, but the container homeassistant does not install. Sorry for cross postiung, but I am a bit opf panick, wish to get it up and running
root@ubuntu:~# curl -sL https://raw.githubusercontent.com/home-assistant/hassio-build/master/install/hassio_install | bash -s -- -m intel-nuc
[Info] Install supervisor Docker container
[Info] Install supervisor startup scripts
[Info] Install AppArmor scripts
[Info] Run Hass.io
root@ubuntu:~# ^C
root@ubuntu:~# docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
ee3e859e25a2 portainer/portainer "/portainer" 4 minutes ago Up 4 minutes 0.0.0.0:9000->9000/tcp suspicious_albattani
root@ubuntu:~#
After few minutes (doing nothing) also portainer disappeared �?
root@ubuntu:~#
I think that script is not for re installing.
I think you ctrl+c out of the script before it finished.
thanks for noting, but no, it was just a bad copy/paste, in reality I did not do CTRL C
Great tutorial, now I have just one question. If I install Samba Add-on, everything goes ok, but what if I want to have access to the Hard Drive of my Ubuntu PC? How can I set up a samba share to both?
Sorry for the noob question
Iâm not sure if the hass.io samba supports sharing other directories.
An option might be too disable samba share add-on then configure samba share in the host os.
The hass.io directory is
/usr/share/hassio/homeassistant/config
I think I will go that way. disabling the add-on and setup the directory. Thanks! didnât know what directory was.
Thanks for the reply.
All commands were executed as root. Its obviously something to do with the fact I am using the windows 10 Ubuntu app. There are limitations to the app, such as no systemd. Is there any system dependencies you can think of that would cause the supervisor docker install to fail?
What steps would I need to take to erase my failed attempt and make a fresh attempt at rerunning the installation steps?
how would you go about updating after installing this? will it work via the menu in hassio?
Yes, menu.
Great.
Managed to crash my installation yesterday. Installed Hassio on Ubuntu18.04 following the steps here. So hopefully I can update to 86.2 using the menu without breaking my installation?
Excellent instructions. Worked perfectlyâŚuntilâŚ
When I click in the addon store for anything eg. SAMBA, nothing installs.
It goes through the process and then says: âAddon is not installedâ
any ideas?
I followed your instructions (thanks to frenck) and I now have hass.io working in docker.
If hass.io ever stops working for whatever reason (letâs say a botched upgrade) and I need to re-install do I follow the same commands or are they different?
fyi, I do backup my config directory.
thanks
Cross this bridge when it comes. Issues with upgrades can be handled with via various means. Uninstalling and restoring is not the only or the most effective method of dealing with an issue.
Actually, it already happened when I upgraded to 86.4 and I could not get the gui to show. The log showed no errors. I wasted hours trying to debut but I finally gave up and used portainer to kill of the home assistant containers and then followed the original instructions to install again. I thought that maybe that was overkill and there is a simpler way to recover.
is it possible to âseeâ USB devices plugged into the Ubuntu machine from dockerised HASSIO?
I want to install this but am worried my RFLINK device wonât work when I connect it to my Ubuntu machine
I canât check as Iâm now using home assistant in docker and not hass.io in docker.
In docker you have to specify privilidged = true or specify the usb address to have access to usb devices.
How do I restart hass.io after a system reboot?
Actually, I am not sure whatâs running and what not.
$ docker ps
38979625382b portainer/portainer "/portainer" 3 minutes ago Up 3 minutes 0.0.0.0:9000->9000/tcp peaceful_stonebraker
$ docker image ls
REPOSITORY TAG IMAGE ID CREATED SIZE
portainer/portainer latest 19d07168491a 23 hours ago 74.1MB
homeassistant/qemux86-64-homeassistant 0.88.2 ec96e9d6a77b 6 days ago 1.17GB
homeassistant/qemux86-64-homeassistant latest ec96e9d6a77b 6 days ago 1.17GB
esphome/esphome latest 59d062ff82c4 7 days ago 555MB
homeassistant/amd64-hassio-supervisor 145 a5e7b092ba19 12 days ago 200MB
homeassistant/amd64-hassio-supervisor latest a5e7b092ba19 12 days ago 200MB
ubuntu latest 47b19964fb50 4 weeks ago 88.1MB
Everything worked fine until I rebooted. Hardware: x86 with Ubuntu.
Thanks in advance for help with what I hope is a trivial issue.
