Thomson router telnet error
hi guys,
i was supplied a new router by my isp and i noticed its supported by home assistant. yet when i add
  - platform: thomson
    host: 192.168.1.254
    username: xxxxxx
    password: xxxxxx
i get this error message
2018-04-30 22:17:42 ERROR (SyncWorker_12) [homeassistant.components.device_tracker.thomson] Connection refused by router. Telnet enabled?
  File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/thomson.py", line 94, in get_thomson_data
    telnet = telnetlib.Telnet(self.host)
  File "/usr/lib/python3.6/telnetlib.py", line 218, in __init__
    self.open(host, port, timeout)
  File "/usr/lib/python3.6/telnetlib.py", line 234, in open
    self.sock = socket.create_connection((host, port), timeout)
  File "/usr/lib/python3.6/socket.py", line 724, in create_connection
    raise err
  File "/usr/lib/python3.6/socket.py", line 713, in create_connection
    sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
2018-04-30 22:17:42 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform thomson
whats telent and can i turn it off?
Telnet is smth you can learn about on Google and I suppose you’ll have to enable telnet on the router for this to work.
Also are you sure your router got this ip?
What’s the model of the router?
my router is: MediaAccess TG589vac v2
I access it via 192.168.1.254, this was set when I first hooked it up
Try to connect to your router via telnet, to see if your username and password are correct.
You can use putty for example if you’re using Windows.
You’ll find a lot of guide online.
For the password and username you can have a look here:
https://forum.kitz.co.uk/index.php?topic=20044.0
And if this doesn’t work, check if telnet is restricted, as explained here:
Thank you for this I’ll look into it
coming back to this
I exported the config but it saves as a bin file which I can’t edit. I’ll just have to try nmap
Try to rename it as zip and extract it
change it to .zip doesn’t do anything
Ok then I’m out of option ^^
I appericate your help
Thank you
